Follow Paul's instruction on "centering the rack"...
- Drop the tie-rods out of the steer arms (if not already done).
- Take a tape measure, and find an easily repeatable spot on the fore and aft of the rotors, as close to the horizontal centerline as you can - somewhere you can slide the tape measure through frame obstructions and hit the same spot repeatedly. Measure front & rear.
- Tap/Knock/Push the L & R side spindle assemblies and re-measure until they are the same distance apart fore & aft.
- Thread on one side tie-rod end. From where it catches threads, count the number of full and half-turns it takes to where it will fit into the steer arm without moving the spindle very much. Take into account the angle, etc. - the shaft of the tie-rod end should just push up into the steer arm. Thread on the tie-rod nut finger tight.
(This is another spot where a daub of anti-seize on the threads would be a good thing)
- Using the number of turns from above, thread on the other side tie-rod end, and snug it into the steer arm.
- Re-measure the fore & aft distance between the rotors. If you did the above correctly, they shouldn't be too far off/different.
Here's where you can fine-tune your base setting.
- Remove the dust boot clamp from the small end of the steering shaft(s) on the rack (the shaft where the tie rod end threaded onto). Just move it onto the shaft, so it's not clamping the boot - the shaft can spin inside the boot.
- The rack shaft(s) has a hex section on it, where you can get a wrench on the shaft. You will be turning the L & R rack shafts with this hex. (it's a ball/socket joint, you're not unscrewing anything from the rack)
- Make a mark on one of the hex flats for ease of counting turns.
- Taking repeated fore & aft measurements off the rotors, turn the L & R rack shafts EQUALLY clockwise or anti-clockwise to move the spindle/rotor assemblies until you've achieved about a 1/8-inch "toe in" (front/fore measurement is 1/8" less than rear/aft measurement. (Pigeon toed) If you crank the DS a half-turn, crank the PS a half-turn. Stay equal.
**While doing this keep an eye on the dust boots. They have a habit of sticking, and wadding up.**
You've just successfully done a rough toe-in setting.
