Thread: Coyote PCV for BAR.
    May 2016
    North of sacramento Ca.
    Coyote PCV for BAR.
    Would you look at my PCV on A50XS cj, i have it as came. Going to BAR on 17th and want to make sure it is right!IMG_8211.JPGIMG_8212.JPG
    Heart of Dixie, Alabama
    You have it right. I have the same engine. Rather than plumb the drivers side into the intake tube, I plan on using a push on filter. I ask Ford Tech about the DS line and he said, run it like you have.
    Where did you get your adapter from the throttle body to air intake? Here is what I ended up with,,, so far. 20180902_130723 (1).jpg
    May 2016
    I made it. Now i am working on a twin turbo setup, but need to learn more about all the parts!
    Nov 2015
    Elverta, CA
    Quote Originally Posted by 1932 View Post
    Tommy, you are nuts! What's next, a set of wings?? good luck at BAR. Stop by and let me hear how BAR went. Seeya
    Gatineau, Quebec, canada
    Here is how mine is setup
