Likes Likes:  7
Results 1 to 8 of 8
Thread: Oil gauge issue
    Jan 2015
    St Catharines Ontario Canada
    Oil gauge issue
    Hello everyone. I have had an issue with the oil gauge FF supplied. At first it stoped working when I came to a traffic light and the oil pressure dropped below 25psi. Then I started to bounce like it was possessed and now it will only work if the pressure is above 75psi. Is it the gauge or the sending unit? I am running a SBC old school gen 1. I installed the sending unit jus above the oil filter on the drivers side.
  2. Likes wrp liked this post
    Placitas, NM
    Have you checked for loose connections?
    The sender works on changing resistance as the pressure changes.
    If you have a few resistors you could use clip leads to connect them to the sender wire and ground to see if the gauge is working.
    75 PSI is pretty high for a SBC. My last one only ran around 50PSI (hot) at speed.
  4. Likes wrp liked this post
  5. #3
    Senior Member TomH33's Avatar
    Nov 2016
    Parker,CO
    I have built a bunch of small block chevys (as well as the 400ci in my 33). I have always mounted the sending unit next to the distributor on the block and thay all worked fine.
    TomH33
  6. Likes wrp liked this post
  7. #4
    Jan 2015
    Thanks guys. Tom do you have a photo of the location. It was never 75psi before. I do have a high volume pump on it.
  8. Likes wrp liked this post
  9. #5
    Nov 2016
    Parker,CO
    Here is the best photoI can do. You can use 1/8"NPT tubing or 45 degree fittings to make it fit under the distributor. _DSC0109.jpg_DSC0110.jpg
    Have more questions, just ask.
    TomH33
  10. Likes wrp liked this post
  11. #6
    Jan 2015
    Thanks Tom I am going to try that.
  12. Likes wrp liked this post
  13. #7
    I had one go bad. And when I worked on replacing it I foolishly used thread sealer to ensure it didn't leak. What I accomplished was to avoid the ground necessary to make it work. Here are some shots of mine. I like the angled installation Tom did but mine had a short piece coming up form the block then two 90's to offset it. Has worked pretty good. Bottom line is what Tom says.
  14. #8
    One thing I noticed with these gauges is that even if you use the push on connectors on the gauge you have to make sure the nuts are tight on the screw posts.
  15. Likes Niagara Dave liked this post
