Missng piece on door Drawing
Hi
I have a question about the door hardware. I was just mocking up the door hardware when I noticed a part I do not seem to have. On page 392 you have a mechanical drawing of the door hinge assembly. On the right hand drawing you show a piece of metal that is not labeled. You show it as going under item #1 and the top hinge. I have two pieces one for the front inside door frame and the other I don’t know. The holes in both pieces are to small to fit for the bolts your using. Not sure what this is or where to find it.
