Body work question
I'am finally at the point of starting the body work on my MK4. After reading a lot of threads I have started to sand and clean up the body as per EdwardBs suggestions. One question that I have is where the fiberglass body raps under the frame (between the front and rear wheel wells) there is a screw hole that was used to hold the body in place for delivery. It has been suggested to straighten this piece. Does the fiberglass body get screwed into the frame? If not does it make sense to eliminate the screw hole by sanding it down or filling it in?
Craig
