Thread: Inboard lap belt mounting tabs
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    As I'm sitting here contemplating step 234,487, I looked at the inboard lap belt mounting tabs.
    Those things are right next to the tunnel tin... How are you to get a nut & wrench in there to tighten the bolt?
    I'm thinking of punching a hole in the tunnel panel for bolt access, then a rubber hole plug to seal it up.
    Ideas??
    John D. - Minneapolis 'Burbs
    Jun 2015
    Ancaster, Ontario
    Great timing...I am wondering the same and thinking of doing as you suggest.
    MKIV #8740, Canadian base kit, Picked up Dec. 2015, ‘98 Cobra 4.6 l DOHC, T45 transmission, old style IRS, Art Cuesta dieted harness/Ron Francis chassis harness, go-cart July 2018.
    Put a pry bar between the aluminum and bracket and massage it till you have enough room...da bat
    Drill through the aluminum so you can run the bolt from inside the tunnel and plug it with a rubber plug/grommet, then carpet over the plug after the belts are attached.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    That's what the instructions say to do -- drill a hole through the aluminum and put the nut and washer on from inside the transmission tunnel. Sounds a little weird, but it works fine.
    Chino Valley, Arizona
    That’s what I did and all is good...
    Raleigh NC, OIB NC
    Quote Originally Posted by cgundermann View Post
    + A whole bunch. Don't make it any harder then it needs to be.
    Kevin
    MKIV #8234
