Results 1 to 2 of 2
Thread: Analog Smith’s speedometer with Coyote and TKO600
    Krakow, POLAND
    Hi everybody 🙂
    Have you any experience with analog (wire) speedometer in FFR? I have MKIV with Coyote engine and TKO-600 trans. Coyote need digital signal also or not? And what to go with dash harnes cable for speedo?
    If I understand, you're talking about a spinning cable from the transmission to the speedometer? If so, only a matter of having the right gear on the speed sensor to get the proper speed reading.
    If you have the crate engine version of the Coyote, with the Ford Performance controls pack and the TKO, you don't need a speed signal. Only +12 volts to the Coyote system and wired per the instructions.
