Results 1 to 9 of 9
Thread: October Roadster Build School
    Senior Member VAHokie's Avatar
    Chantilly, VA
    Signed up for the October Build School, Oct 19-21, who else is planning to attend?
    For those that have attended previous schools, any recommendations for preparing? I've read the manual a couple times, noting questions needing answers while there; read numerous Build threads with copious note taking; watched the videos; and actively monitor/read threads on the forum - what am I missing to ensure I get the most out of it?
    Elk Grove, NorCal
    I went in July 2017. Sounds like youre on track. I took a lot of photos and marked them with notes which is helping me in my build...like brake line placement, fuel lines, and little things here and there. Im pretty much assembling mine in the same general order. They have a good crew teaching and youll have fun. After class some guys and instructors go out to dinner.
    Travelling from California I made a vacation out of my trip. One thing I did was arrive a day earlier and toured the Ford Museum, ford factory, and Greenfield village, and Detroit. On the back end after the class I went to visit the Roush facilities and museum and also went to Ann Arbor.
    Kit purchased: July 25, 2017
    Senior Member Clover's Avatar
    Colorado
    First off, you are going to have a blast, or at least I did and I think the rest of my group did as well. Sounds like you are going to be a lot more prepared then I was as I had only watched the videos and read posts on here. I would recommend that you plan your order before you get there so you can ask specific questions about what you are going to build. You can also look at the specific options where you are there. This saved me money as I decided there were a few things I did not really need.
    Plan out ahead of time how you want to take notes and pictures. There was a guy in my build school that had a numbered notepad. He would take a picture of the number, then a picture of a part of the car. He then added his notes on what the picture showed under the associated number in the notepad. Later they typed up his notes to go along with each picture and it was very helpful to be organized. Now that I am going back through my notes, I wish I had been set up like him. I am sure there are other methods that work for different people, just plan out a system that will work for you.
    I took an extra day after the build school to go tour the Roush factory which was terrific. I was like the gearhead equivalent of Charlie and the Chocolate Factory. I think five of us ended up doing the tour which was eye opening. They are so much more impressive then I ever knew. You just need to go to understand everything they are involved with. Vipers to WWII Merlin Mustang engine restorations. The factory is basically in Detroit, so I went on the tour before my flight home.
    Lastly, the group tends to go out to dinner after each day. I recommend you go as we all ended up having a great time and building some good friendships.
    Gen III Type 65 Coupe Delivered 6/26/2018
    Chantilly, VA
    Thanks, Vspeeds and Clover.
    I have travel days on either end of the School so probably not going to make the Ford Museum, Roush factory, etc., but great suggestions. I have my Build plan together and will definitely use that as a guide for questions and areas to focus. I like the idea you shared Clover for aligning notes with pics - still thinking through my approach for that but probably something similar given my type A, OCD personality. I'll definitely be participating in any dinners or social activities - valuable time to further dig into Build questions and building relationships.
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Sounds like you have good advice. I'll repeat to take plenty of pics and notes. I went in July of '16 and enjoyed every minute. I'm about 75% into my build and still find the info usefull.
    JR
    Chantilly, VA
    Thanks, JR.
    Stafford Virginia
    Any time you would like to come down and see my build you are welcome. PM me for info. If you are interested. You may want to wait a couple weeks there is another guy 5 mins. from me thet has a Mk3 on the road but he is on vac and not home.
    JR
    Fairfax Station VA
    Likewise. Anytime you would like to drop by, I'm in Fairfax.
    Also, ScottieC is in Chantilly as well.
    MK IV Roadster #8631
    Chantilly, VA
    Thanks, JR and John. I'll definitely take you up on those offers - will send PMs.
    John, I've actually already connected with Scottiec and he was nice enough to give me his body buck! ��
