Results 1 to 3 of 3
Thread: New style headligths and Ballasts?
    Good evening,
    Does the new style 818 bi-xenon have an internal ballast or external, if it did not did you receive them or do we not need a ballast?
    Leesburg, VA
    The new style head lights are just Hella projector lamps with normal halogen bulbs. You can replace the halogen bulb with any aftermarket HID (xenon) bulb, which will require a ballast. I chose to install LED bulbs (same ones as Frank818):
    https://www.ebay.com/itm/80W-8000LM-...oAAOSwHUVa6I0-
    QC, Canada
    Correct, single bulb halogen headlamps (from FFR).
    I think LEDs are better, but it's up to what one wants.
    Those LEDs above have a small fan to cool them down. There are MANY various other models available, some with fan some with heat sink.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
