Was watching the FFR Video #9 on fuel tank install. They recommend 'Seal All' for the rubber o-rings. I've never used a sealant like that on o-rings...only motor oil or vasoline. Anyone use the stuff?
I use Molykote 111 on rubber gaskets and o-rings. Commonly used in the Porsche world
https://www.amazon.com/dp/B00CTUJNU2...537429950&sr=1
If you are talking about the o-ring around the fuel pump and fuel gauge, motor oil as per Ford, same for the fill tube.
Are they suggesting using seal all instead of an o-ring?
They are suggesting to use the Seal All on the o-rings of the fuel tank sender and pickup. Here's the video. They apply the Seal All at 1:43 and 2:38
https://www.youtube.com/watch?v=ybGdqmVyDV4&t=200s
FFR supplies a Dorman aftermarket Mustang tank....close, but not exactly like a ginnie Ford tank. When I build I use a sealant. On a Ford tank with Ford O-Ring I use a lightweight oil..Da Bat
