Thread: In Tank Fuel Pump for Carb
    BadAsp427's Avatar
    Greeneville, TN
    Does anyone know if there is an In Tank fuel pump available for use with a Carberated set up? I've looked everywhere and have not been able to find one. Thanks for your help.
    Carl
    Jun 2018
    Carl
    I just converted my FI setup to a carb, and we used the FI pump that was in the tank, I just had a fuel regulator installed that lowers the pressure to 5-6psi, as I recall the pump in my tank is a Walboro 255
    Northern VA
    What Caesar said. I decided to go with a mechanical pump due to simplicity. However, you will need to swap timing covers
    Grand Rapids, MI
    Aeromotive makes the A1000 carbureted bypass regulator. Kinda pricy but very nice. Just make sure what ever you get is a return style. Dead head regulators and in tank pumps don’t always go well together.
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    I plumbed my car for a return line, but in the end I actually went with a low-pressure in-tank pump that dead-heads to my carb.
    This pump has been feeding about 6psi to my 600cfm VacSecondary carb atop my 302 without any problems so far.
    https://www.amazon.com/gp/product/B008M4R69E/
    And this strainer sock
    https://www.amazon.com/gp/product/B008M4RLRG/
    about $30 for both, a pair of stainless steel hose clamps to retrofit it to the factory hanger... and good to go!!
    2016 MK4 | '99 Explorer 5.0 | E303&600cfm carb | T5z + 3.55 | 3-link | SN95 | PB/PS | FR500 17" 315&275 |
    Senior Member Norm B's Avatar
    I used the stock fuel injection pump and this regulator with a return line. https://www.summitracing.com/int/par...2015/overview/.
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by skidd View Post
    Thanks for this info... I just ordered the pump and the hanger I'll need... I will be much happier with the pump in the tank and out of the way... Thanks again.
