Results 1 to 10 of 10
Thread: Battery Cut-off Switch
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Looking for some recomendations for a battery cut-off switch.
    Moroso
    Senior Member karlos's Avatar
    Littleton, CO
    Have the Moroso. Works fine. But this is way better; way more expensive, too. The bypass circuit is a nice feature, as is the remote mounted switch to activate the unit.
    https://watsons-streetworks.com/prod...ry-disconnect/
    MKIV Roadster #8641
    Complete Kit with IRS, Eaton Detroit Truetrac, 3.55 gears, Wilwood Brakes
    Ford Racing Z427 w/ Pro-M Sequential Port EFI System
    TKO 600 + McLeod Midshifter; Fast Freddie's Electro-Hydraulic power steering
    Miller Customs Bodywork & Paint
    Mar 2017
    Thanks.
    I like the remote unit is nice (but pricey).
    Mark
    I've used the Ron Francis MS-1 master disconnect several times. Rated for 200 amps, seems well built, and is reasonably priced. I like the boots they provide for the connections too.
    Grand Rapids, MI
    This is subjective as there are no “bad” cutoffs. They just have different features. Some have a remote cutoff, some have a removable key, some are just on and off. Heck some attach between the battery and the cable. Personally I installed a Hella one with a key. I call it a extra theft detergent. Your only main concerns should be amperage rating and making sure you get insulating boots for the cable lugs. Allstar Performance makes a nice set you can get through summit racing for cheep.
    Copperhill, TN
    I use a basic one, from Breeze I think, with the removable key. Buried it on the horseshoe aluminum under the dash, and with the key out, you can’t really see it in the black carpet. If I leave the car somewhere, I remove the key and lock the hood so you can’t get to the back side to by pass, so sort of an additional anti theft step. I just turn it off while in the garage and it’s on the trickle charger.
    Found the one I used
    https://www.breezeautomotive.com/sho...able-red-flag/
    I purchased a Keyed Switch from West Marine made by Sierra.
    While I found a bunch of "Look-A-Like" switches at several local auto parts stores none had the amperage rating of the Sierra piece.
    Continuous Rating: 350 Amp, Intermittent Rating: 500 Amp. 12, 24 & 36 volt systems
    I've got it mounted in the footwell on the passenger side of the car so that the key can be easily removed, along with my steering wheel.
    Hopefully, this might be a good option for you but if it isn't then I know you will get a host of great suggestions here on the forum.
    https://www.westmarine.com/buy/sierr...CABEgIhj_D_BwE
    Mar 2017
    Good suggestions. I like the removable key option.
    Thanks all
    I had a battery switch for maybe 7 yrs. Used it maybe 5 times. I moved the battery to the front 5 yrs ago and basically didn't feel like bothering w/ a switch. I haven't missed it once.
