Results 1 to 4 of 4
Thread: All Wheel Drive
    Sep 2018
    All Wheel Drive
    I've been looking at the design of the '33 and have made not of how far behind the front suspension the engine sits. This pit the idea that a there might be room up there for a dif and half shafts to put power to all 4 wheels.
    Anyone else had this idea?
    Prairieville, Louisiana
    Yep. It would get pretty tight with the inboard shocks. Getting the forward shaft in to the diff would tight under the motor. But if you movie the shocks outboard, I think there might be enough room for a small diff.
    Check out Troy trepaniers quadraduce. He used the running gear from a cyclone/typhoon if I’m not mistaken.
    '33 Hot Rod
    MK4 Roadster
    May 2019
    It'd be cool. I wonder how the old Silverado SS was setup.
    Senior Member jayguy's Avatar
    Las Vegas
    The Power Nation show Truck Tech is doing a 4x4 to AWD conversion on a GM pickup now, using the transfer case from the SS and lowering the truck. They call it Project Red Tide.
    https://www.powernationtv.com/shows/truck-tech
