Results 1 to 6 of 6
Thread: Front brakes base kit.
    Prairieville, Louisiana
    I currently have the base kit front brakes. I want to upgrade them, but I want to use something that I can get at a local parts store if needed. Wilwoods that FFR sell are out.
    Are these brakes mustang based? Like, if I get bigger rotors and calipers that would be an upgrade on a mustang gt from whatever year, would that work (aka, if they are 2000-2004 based, would aftermarket upgrades to those years work?). And if so, what year range and model are they from? Or am i completely off base?
    My rears are already 2000-04 GT brakes so I’ll toss some slotted or drilled rotors on and call those done. I do want to upgrade to much larger drilled or slotted up from with calipers to match.
    '33 Hot Rod
    MK4 Roadster
    They are 2004 Mustang Gt front brakes.
    Norton, MA USA earth
    Look up 94-95 Cobra brakes. 13 inch rotors and dual pistons. I bought a complete set on Rock Auto pretty cheap.
    Lost Wages, Nevada
    Only question; what size wheels are you running?? Funny as it may sound, wheels seem to decide how BIG you can go (rotor-wise). Larger piston calipers are a good place to see some significant gains as well as multiple pistons if you have singles now.
    I have 13" rotors on my MKII with 17" wheels and could probable go to 14". Fronts are the Pro Racing (PBR) Cobra calipers, rears are the late model T-Bird single piston version riding on 11.63 rotors. Car does not have power brakes and it stops very hard with that combo. If I was going to upgrade from here; larger rotors in the rear to more closely match the fronts and dual piston PBR's again.
    Don't overlook more aggressive pads like the Hawk brand for street/race . . .
    Doc
    That’s exactly the info I need! Thanks guys!
    Doc, I will be running, probably, 20” wheels. I know what I want, but haven’t found exactly that yet. A 20” chrome wheel with long, thin, spindley spokes, with lots of depth in the rear. So I want some nice brakes to fill up some of that empty area but stillbe able to get parts at a local house to get rolling again if needed. Sounds like Mike’s recommendation for 94-95 13” setup will work great. I’ll have to check 03/04 cobra brake sizes also.
    '33 Hot Rod
    MK4 Roadster
    Village Mills, Texas
    Quote Originally Posted by Big Blocker View Post
    Doc
    I don't mean to hijack this thread but I have a quick question. I have the 11.63 single piston 11.63" Cobra brakes on the rear. Will 15" wheels fit on the rear.
