Remote oil filter - oil flow question
I will be using a remote oil filter as well as an oil cooler. It was my understanding that the oil will leave the engine block, travel through the oil filter, out the oil filter to the oil cooler, and finally out the oil cooler back into the engine. The picture below depicts that route.
When I received some parts, the instructions showed the oil flow with the filter after the oil cooler. Now I'm confused as that makes more sense to me as the oil is filtered prior to circulating back into the engine.
What do you guys think?
Would there be a pressure issue either way?
build thread:
http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
Kit purchased: July 25, 2017
I've had a little experience with this... I've always gone with the filter before the cooler... this will insure that you are only putting filtered oil into the cooler. Could prevent build up of stuff thus decreasing the available flow of the cooler. Also, if you have a thermostat valve, you would want to go engine -> Filter-> Thermostat valve... if you did not do this, you would not filter the oil until it was up to temp.... Hope this helps and makes sense... Bottom line IMO, it is always best to filter before cool...
I thought I would chime in to address the concern over the issue of oil not being filtered if the temp isn't hot enough. The way the oil thermostatic valve is designed, oil flows into the unit and if not up to temp, it flows out of the valve and resumes the flow through they system. As shown in the diagram above, the oil would leave the valve and route through the filter and back to the engine.
On the other hand, if the temp is hot enough, when the oil flows into the thermostatic valve, the valve opens up, and allows the oil to flow through the oil cooler and back through the valve, before being routed back to the filter and into the engine.
In other words, the oil will be filtered regardless of temperature, and the diagram provided above is correct. Now, if you are concerned about the oil being filtered before going through the cooler, that's a separate issue. I just wanted to correct the possible confusion regarding oil flow with the presence of the thermostatic valve.
I hope I have helped!
Originally Posted by
WIS89
Thanks for the clarification Steve... Carl
Thanks for the info guys. I will not be using the thermostat valve. That diagram just through me off. So far it seems the best way is to filter the oil before the oil cooler like in the first picture. One of the reasons I've gathered is to not let the oil cooler get contaminated which could impede the flow of oil.
build thread:
