Results 1 to 3 of 3
Thread: E-Brake cable route
    Jan 2016
    E-Brake cable route
    I am ready to make the final install of Wilwood rear brakes on a Moser three link and I have a choice of either a forward or rear facing connection for the E-brake cables. I am seeing plenty of examples of calipers going either way. The rear-facing mount appears to create a large U-shaped bend under or around the rear shock mounts and looks a bit awkward. Would a front connection be more direct? Advice either way would be welcome. Thanks in advance.
    Gatineau, Quebec, canada
    This is how we routed mine. Hope it helps.
    Placitas, NM
    Quote Originally Posted by AJT '33 View Post
    Same way for me too.
