Guys,
Are these the brake light switch?
Or something other.
I am running a 5.O coyote motor.
Martin
Guys,
Or something other.
Martin
Gen 2 Coyote has a clutch switch in addition to the brake switch that must be used to start the engine. Gen 1 only needs the one for the brake lights (your choice on using the clutch one)
Kevin
MKIV #8234
Imagine one is for brake, one for clutch. Not sure about coyote wiring, it may have the clutch switch wired into its harness somewhere but on the Ron Francois harness there are plugs for both the brake and clutch switches.
You should also have some small mounts to hold the switches to the pedal box, hopefully you have not installed the pedal box yet? Should show the install for the mounts in your manual
Thank you all
The coyote fitment kit came with a two clutch switches, one down and one up.
Martin
Kevin
MKIV #8234
Later versions of the Gen 2 Coyote (and now the Gen 3 Coyote) eliminated the top clutch switch. Only have the bottom one now. But for your Coyote, sounds like you have two. If you also purchased the Coyote install kit from Factory Five, they provide brackets to mount the Ford provided clutch switches. You won't use the one pictured for the clutch. You will for the brake though as already mentioned.
So the later version got rid of the top clutch switch? I believe I have the later version and the clutch switch seemed to have come with the engine. There is a connector on the coyote harness for it still. If I do hook it up, will I see a fault?
If Ford provided the top clutch switch in your controls pack and the wiring harness has a connection for it, you need to use it. I would expect the version of instructions you received also shows the top clutch switch. I'm quite certain the program in the PCM you received is expecting it, and I couldn't predict what would happen if left off. Later versions of the control pack eliminated all three: The switch, the connection on the harness, and the reference to both in the instructions. Factory Five also updated their instructions to not show the top switch any longer.
A little background: The top clutch switch was added to the Gen 2 Coyote controls pack to solve an issue encountered with the Gen 1 setup. There was an ongoing issue with the Gen 1 dying when coming to a stop which Ford resolved by adding a speed dial module. I'm not really sure what it did, but apparently solved the problem. When I bought the Coyote setup for my #8674 build, found it was a Gen 2 version, and before there was a lot known about it. I called Ford Performance and asked if the speed dial module was required for the Gen 2. They said no. The top clutch switch along with added programming in the PCM solved the problem. I've never had any kind of dying issue with my Gen 2 setup, and others installing them reported the same. Apparently now Ford has figured out how to solve the problem with programming only and has eliminated the top clutch switch for very late Gen 2 Coyote crates. My recently received Gen 3 Coyote crate also does not have the top clutch switch. But if your version of the control pack has it -- use it.
Great info guys
Thanks for great info-
I think I have a late release gen two-I will confirm with Mike Forte
Martin
Thats what I thought too but apparently i don't. I ordered and received my motor in August this year. Looks like very late model is not an exaggeration
Check the footbox end of your Coyote wiring harness to see if you have a connection for both Ford supplied switches. In my case, the controls pack included both top and bottom clutch switches, and I mounted both, only to discover later that the wiring harness only had a connection for the bottom travel switch, so I removed the top travel switch from the pedal box.
Great Call Shark
I will do that
Thanks again
Martin
