Hello,
Quick question for you guys. Trying to install my lower steering shaft today and noticed that it did not even come close to fitting through the bearing. As you can see from the photos, the steering shaft is oval and 1", while both bearings received are 3/4" i.d. My build inventory shows that I should have received the 3/4" pillow bearing and a 1" flange bearing. So it appears the pillow bearing is correct, but I may have received the wrong flange bearing? Just wanted to confirm before I call Factory five tomorrow that I am not overlooking anything. For those of you who ordered the base kit, did you receive two 3/4" bearings? And was I supposed to get the 1" bearing with the power steering kit? If you did get the extra bearing, any idea on the box it came in? Thanks in advance.
