Results 1 to 33 of 33
Thread: GndHog's Gen 3 Coupe-R Coyote XS 5.2 twin turbo build by LR Classics
    May 2018
    Moving build thread here as hopefully Gordon will get chassis this week and away we'll go. Worked and rework some build points on car - have pretty much set plan now baring any unforeseen issues that may arise. Will try to get as many photos/updates from Gordon posted here.
    Updated "final" build specs -
    FFR Gen 3 R coupe kit
    5.2xs crate engine
    Garrett twin turbo with custom intercooler
    32ga fuel cell for E85
    dry sump oil system
    custom oiling system parts
    custom fuel and oiling system install
    Lenco 6r80 trans w. controller and shipping
    LoKar ESS6R80HB shifter
    paddle shifter
    Circle S custom converter
    electric power steering
    AP rear brakes 365mm w/17mm pads
    AP front brakes 372mm w/25mm pads
    set Penske DA8300 shocks w/ remote canisters
    Billet front control; arms
    general assy
    Body & Paint Labor- estimate, add roof scoop and flares
    Materials
    Forgestar wheels X8
    cams m-6550-M52A
    misc
    aero front bumper - FFR
    front canards - FFR
    carbon splitter - FFR
    coyote engine harness
    Alt and bracket
    flexplate
    Carbon rear wing - ACR GT1000
    cromoly drive shaft
    tran cooler
    AEM controller
    upgrade valve springs
    cylinder head studs
    Billet cam tracks
    Donor IRS 3:73 w torsen
    Sparko Ergo X2 seats
    Sparko R353 steering wheel
    cam phase kit
    AEM 30-5502 dash
    engine labor
    fire system
    set DOT tires (ACR viper setup)
    May 2018
    Well - Stewart transport had some issues and body/chassis sitting at warehouse in Phoenix - some 65 miles away from Gordon - but hopefully, almost, maybe car will get started on this week.....maybe get some pics up soon
    May 2018
    Aug 2017
    Michigan
    Excellent!
    Senior Member q4stix's Avatar
    Seattle, WA
    Awesome! Glad to see it finally arrive. Now we get to see the real progress all the planning put into motion!
    Gen 3 Type 65 Coupe builder
    May 2018
    Transmission getting fitted in tunnel - mounting a now 32 gal fuel in the rear - along with dry sump tank in the back / and figuring out where to put half a dozen various exchangers will be first on the plate for Gordon to tackle.
    Radiator standard location - trans cooler, air/water exchangers for turbos, Oil cooler, maybe a differential cooler as well (in rear) - not to mention stuffing two 72-76mm turbos under hood and associated dump valves and exhaust piping will make for no free space just about anywhere in car.....
    May 2018
    Transmission bell housing a little wide - some frame tubing will need "adjusted" - looks like 32 gal fuel cell fits without issue - waiting on getting some photos still - will add as soon as I get them. Hard being 10,000 miles away.....
    May 2018
    Turbos placed - just in front of foot boxes - left/right twin Borg Warner EFR-8374-1.05 non waste gate. Gordon tried the Garrett 71mm's - but didn't fit - just too big of diameter....
    The Borg Warner twins should spool up just fine. Going with water intercooler exchanger for air charge into the Cobra Jet intake. We should hit max power around 21-22 psi - so nothing crazy high on boost. Lot's of items to fit still before chassis goes to powder coating. Looking to see if Bosch ABS might be within the ever expanding budget - car is going to be crazy quick and the ABS will probably save more than one set tires.......
    Gordon taking his time to do it right (which I fully support) - there is no rush to get car out. Have my ZR1 to play with when I final get out of Saudi for good - which is just 3 weeks away....ah home, home sweet home soon....
    Seattle, WA
    Now we really need some pictures!
    May 2018
    Pictures will come - Gordon trying to get all frame mods done then will take some shots when everything "fits"
    There will be 6 vent ducts running through front air dam (fog light holes will get duct work behind them) - so - the splitter, air dam and front 1/4 of hood will get hard mounted somehow - split hood from mid fender wells to radiator opening to allow front 1/4 to stay on car and back 3/4 to be lifted off for working on motor. The tilt up hood just doesn't work well with all the aero nor with all the ducting that needs to go through front part of hood. Some sort of quick release for rear section of hood and front will be more permanent mounted but removable with some work.
    Should look pretty slick and be very functional - functionality for all out racing is primary objective in everything that goes on car.....
    May 2018
    thoughts on how to vary adjustable engine tunes. Very easy to have cockpit mounted knob to move between settings - should be on the fly adjustable as well.....
    Original thought was to have 800, 1000, and max (1300ish) rwHp tunes - with hitting max around 22 psi boost or so.
    Thinking that having 8 psi, 12 psi, 16 psi, 20 psi and max psi (22-ish) tunes might be better way to go.
    Thoughts?
    Seattle, WA
    I know AEM lets you have a rotary switch input for various tables so it makes sense to do something like that. It could be dash mounted or steering wheel mounted that way too
    Heart of Dixie, Alabama
    I got this in my email yesterday. They might have something that will be what you want. I have Lund tunes in 2 of my other toys and look forward to getting one for my MkIV.
    https://mailchi.mp/lundracing/lund-r...r?e=af7fea9380
    May 2018
    Fully aware the AEM will allow adjustable input/s - question was more to base them off of achieved HP or just boost psi limits. Dial a given HP or dial a given boost or level (really the same just a visual thing)
    Seattle, WA
    Gotcha, I misunderstood.
    My personal thought is that actual HP numbers or even HP/100 might get crowded on the labeling. Could you also do a percentage of available power, like 8=80%, 10=100% linear, 11=Max effort everything? That way whatever your numbers are it'll still apply and if you upgrade the turbos later or tune later it'll still apply?
    Of course, if you want to have it stand out and impress people, then go for HP labels!
    Maricopa AZ
    We all need the ludicrous speed button
    Jun 2018
    Apollo Beach, Florida
    Absolutely
    Top Notch Builder P100DHG's Avatar
    Pasadena, CA
    Check that box
    May 2018
    The non-ludicrous setting of 800 rwhp will give more power to weight ratio than a GT series racecar - and should be more than adequate to push me around the track for some time until I learn to handle a measly 800 hp.....
    May 2018
    Gordon get close to send chassis off for powder coat
    Been tweaking on my ZR1 getting her better prepped for track life as well...
    May 2018
    Vette getting plenty of similar parts to the Coupe - including the rear wing. Vette wing picture below.
    Coupe frame getting closer to powder coat - Gordon has redesigned the front section several times as trying to squeeze in all the exchangers for the turbos has been quite a challenge. Most of major components already placed and frame modified to fit them - so once powder coated - assembly should go smoothly.
    FFR Maven Logan's Avatar
    Huntsville, AL
    Vette with the wing looks good!
    That said, I can't wait for more updates on the Type 65 COUPE-R!!!! Bring on the pics and updates to this thread!
    Logan's Gen 3 Coupe-R Build
    Senior Member TheBabyBadger's Avatar
    Jan 2018
    North Bay, California
    Anxiously awaiting updates. Been a minute.
    Gen3 Coupe - SOLD Arrival: 6/21/18 SOLD: 4/12/2019
    Current Vehicle: 2014 SRT Viper (modded to the moon), 2022 TRX, 2014 RS6, E46 LS3 M3
    Current Projects: Superlite/RCR GTR ***FOR SALE***
    @madd_wrapps on IG or www.maddwrapps.com
    Awesome specs and no photos. That’s gotta be some kind of forum rules violation.
    May 2018
    Hopefully Gordon will get some photos to me soon - frame should be ready for powder coating then assembly starts.
    Have told him do it right and don’t rush - have the vette to play with for now....
    It’s actually getting dyno tuned this week and then off to track for some test and tune of suspension setup.
    A few more vette pics while we all wait for the coupe build photos to start rolling in....
    Jan 2018
    Jesus. Modified much...?
    May 2018
    All the Vette mods logged in videos on my
    Channel - Coupe videos will go up there as well.
    Vette will end up around 5:1 lbs/wHP - Coupe will be less than 3:1....
    https://youtu.be/lnFopqZM-Pc
    May 2018
    Sorry for not many updates - CoupeR is progressing along - slowly but steadily.
    Gordon made a trip over to Austin to help with some of the last setup on the Vette. Got to see lot’s of progress photos on the Coupe - hopefully getting frame wrapped up shortly. Some redesign work and trying to fit everything in has been a challenge to say the least.
    Here some lap video of COTA in the ZR1 - can’t wait to get the Coupe-R out there and play.....maybe sept/oct she’ll be ready....
    https://youtu.be/Hys8TIdhX28
    Huntsville, AL
    Still watching and waiting patiently for pics and info of this build. The spec list is ridiculously impressive, let us in on the goods!
    May 2018
    Hopefully will get some photos of assembly soon - going slow and steady and in no rush. It’s been a year but that’s ok.
    Some fun stuff to the fill the void....Miata drivers.....lol
    https://youtu.be/b0CSRmSLJ9E
    https://youtu.be/jmwF4QhKLYk
    May 2018
    Car is in final assembly - car has been a challenge for Gordon as almost everything on car is a one off installation.
    Not sure impact with Covid-19 not consuming the world but car is still moving forward.
    May 2018
    Huntsville, AL
    Awesome! Post some photos please!! Can’t wait to see this beast.
