Results 1 to 3 of 3
Thread: Neutral safety switch
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    I'm running a 700r4 automatic transmission with a lokar shifter. It has a neutral safety switch on it. Can I wire the clutch safety wires to that? I haven't checked the operation of the clutch safety switch if it operates the same way.
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
    Jun 2018
    North Vancouver, BC, Canada
    Sure, as long as you get continuity through the tranny neutral switch when youre in park it should work fine
    Gen 1 '33 Hot Rod #1104
    Apr 2019
    Milford NH
    Thanks I'll check it out.
