Thread: Shifter 700r4
    Jan 2015
    St Catharines Ontario Canada
    Shifter 700r4
    Hello everyone. I am going to change the shifter in my car. I am looking at a Lokar because I like the clean look of it. If you have one what length, did you go with a tale mount, and did you go with a bent shaft or straight? If you could please let me know thank you.
    I went with the Lokar 8"bent
    Senior Member TDSapp's Avatar
    Frisco, TX
    I went with the Lokar with a 24" bent shaft. I am going for the rat fink look in having the 24" shifter. I did do the tail shaft mount just because it looked more secure. Because of the type of tail shaft I had to do a little grinding for it to clear the housing of the tail shaft.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    I have a 700r4 and I went with the Lokar tale mount (Lokar ATS6700ETMM) 20190305_061111.jpg
  5. Thanks colsen23153 thanked for this post
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    I went with the Lokar 23" tall one also, that rat fink look too.20190906_053107.jpg
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
