Results 1 to 9 of 9
Thread: FFR '33 Hot Rod #583 For Sale
    May 2013
    Gainesville, Florida
    Time to move on to other projects, so I'm reluctantly putting my '33 up for sale. Less than 1,000 miles. Fresh 5.0 EFI motor with some intake work, backed by a Tremec 3550 w/ Forte external hydraulic clutch. Ford Trac-Loc 8.8" 4-link rear with 3.73 gears. Air conditioning, power steering, power brakes. Rod tops top and side curtains, Professional body and paint. LOTS of custom touches - including top boot, rear glove box, adjustable seats, hidden Bluetooth stereo system, trailer hitch. Asking less than I have in it. $49,000
    For MUCH more detail, check out my extensive Build Thread on this forum, or call me 352-538-4843 or email me [email protected]. Eric Kraft
    Note: For some reason, the forum keeps logging me out. Not sure whether it is a browser problem, but will try to continue to add specs and pics over the next 24 hours.
    Senior Member TDSapp's Avatar
    Frisco, TX
    Quote Originally Posted by kraftee View Post
    It's the forums way of telling you "NOOOoooo Don't Sell!"
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Nice car! I would love to buy, but out of my $$ range.
    Senior Member Barrel's Avatar
    Aug 2011
    Mornington, Victoria, Australia
    Your '33 is a beautiful car Erik and your decision to sell it gives someone out there a great opportunity to own properly built FFR car.
    I wish you good luck with the sale.
    Neil.(HR#353)
    May 2013
    Here are some specs on the car:
    CHASSIS:
    Factory Five tube frame ID# F5R1000583HR
    ENGINE:
    Blueprint Engines rebuilt HO 5.0 roller cam 225hp (stock) ID #299492
    Ford Mass-Air EFI induction w/ flow-honed intake, 19 lb. injectors, 80mm MAF, Polished 75mm Throttle Body, K&N Air Cleaner
    Approximately 285 hp as built
    TRANSMISSION:
    Tremec 3550 w/Steeda Tri-Ax Shifter
    Forte Hydraulic Clutch Kit
    Ratios: 1st 3.27 2nd 1.98 3rd 1.34 4th 1.00 5th .68 Rev 3.00
    REAR AXLE:
    Ford 8.8 inch 59.25 inch w/ 5-lug hardened axles 3.73:1 with Ford Trac-Loc Limited Slip Differential
    BRAKES:
    Front: 2000 Ford Mustang GT 11 inch vented rotors, dual piston calipers
    Rear: 1991 Lincoln MK VII calipers with re-drilled 10.92 inch Motorsport Mustang rotors
    SPRINGS:
    Front: Koni Coilover w/ 350 lb. springs
    Rear: Koni Coilover w/ 250 lb. QA1 springs
    WEIGHT 2,320 lbs. 1,180 F/1,140 R (51%F / 49%R)
    May 2013
    Factory Five 33 Ford Roadster Hot Rod FFR & Custom Options
    FACTORY FIVE RACING EXTRA COST OPTIONS:
    • Powder Coated (black) Frame
    • Rear Exit Exhaust
    • AutoMeter Platinum Gauge Package
    • Chrome Tilt Steering Column
    • Unisteer Electric Power Steering
    • Rod Tops Roadster Top
    • Rod Tops Roadster Top Side Curtains
    OTHER OPTIONS:
    • Boyd Aluminum Fuel Tank w/ Integral Fuel Pump
    • Whitby Vintage Air AC/Heat Kit w/ Billet Firewall Manifold
    • Whitby Power Brakes Kit
    • Forte Hydraulic Clutch Kit
    • BBK Shorty Chrome Headers & Flowmaster Mufflers w/ Custom Welded SS Exhaust
    • Summit Pulsar Polished Wheels 15 x 10 Rear, 15 x 7 Front
    • Mickey Thompson Sportsman S/R Radials 28x12.00R15LT Rear, 26x8.00R15LT Front
    • Steeda Billet Bump Steer Kit
    • SS Dietz Headlight Buckets w/ Delta Glass Halogen Headlights & Integral LED Turn Signals
    • Everson Radiator Shroud
    • Everson Inner Firewall
    • Everson Molded Radiator Hose Kit
    • Kootenai Footbox Panel & Steering Seal Kit
    • Kootenai Billet Hood Receiver and Pin Kit
    • Kootenai Delrin Bushing Set (Doors, Hood, Trunk)
    • Two Full Boxes of Eastwood Sound/Heat Matting
    • AutoMeter Platinum GPS Speedometer
    • Hagen Fatties Outside Rear View Mirrors
    • Lokar SS Braided Throttle Cable
    • Lokar E-Brake Kit
    • Breeze Seat Sliders
    • Hurst Shift Lever w/ Speed Dawg Custom Shift Ball
    • Leather covered FFR Billet Steering Wheel w/ Custom Horn Button
    • Wesco 3-Point Retractable Seat Belts w/ Aircraft Buckles
    • Boese Billet Gauge Panel
    • L & S Custom Floor Mats
    • Kenwood Hidden Stereo Amp w/ Bluetooth and Infinity Door Speakers
    • Master Battery Kill Switch (Hidden In Glove Compartment)
    • Billet Inside Door Handles
    • Billet Suicide Pin Kit
    • Billet Trunk-Mount Battery Box w/ Optima Red Top Battery
    • L & S Custom Carpeted Inner Trunk Lid
    • L & S Custom Soft Top Boot Cover/Bag
    • 33 Machine Trailer Hitch
    • Pro-Form Braced Diff Cover
    OTHER CUSTOM FEATURES:
    • SS Cables For Hood Restraint
    • Hood Side Panels Modified to Allow Removal With Headlights in Place
    • Custom Braced Hood Side Vents w/ SS Mesh
    • Inertia Switch & Fuse Panel Relocated to Under Cowl Access Plates
    • LED Running Lights in Lower Grille
    • Custom Fiberglass Glove Box Accessed Between And Behind Seats
    • False Carpeted Trunk Floor w/ Storage Below For Soft Top Components
    • Restored 1933 Florida License Plate (Current Registration)
    • High Beam Switch Floor-Mounted
    • Billet Engine Accessory Mounts w/ Serpentine Belt
    • EBC Greenstuff Front Brake Pads w/ Powder Coated PowerStop Calipers
    May 2013
    Won "Best Hot Rod" at a very competitive show this weekend. The judges loved #583!
    Congrats Eric! That is one nice 33 for sure.
    Sep 2018
    Obviously you're a guy who knows his own mind, so your choice to sell that beautiful car is a clear signal that you have something in mind that is dear to you. I am delighted that you chose the 33 and documented the build so thoroughly sharing your unvarnished frustrations and joys because I'll be following your path and building one also. I've read your build repeatedly and refer to it when I am visualizing my build and get stuck on a "how do I do this" issue. Many thanks, Kraftee, best wishes for your nest project. Phil
