My mk4 has manual steering and manual brakes. I have experimented a little with brake pads and they make all of the difference. Do not over brake the car. I enjoy the effort it takes to drive this car, because I wanted it to feel like an original.
Although I wouldn't hesitate to do manual again, a lot of guys on this forum swear by power steering or brakes. It's all preference.
Scottie, which brand and model brake pads would you recommend.
I'm using manual brakes and manual steering on my mk4 roadster. I used a manual rack that I purchased from the factory five. I kind of like the feel of the steering. While it is very difficult to turn the wheel while standing still, once you reach 3-4 mph, there is no problem . The brakes, on the other hand, require a lot of pressure. I've never had to slam on the brakes, so I don't know if they would ever lock up. I'm using the original mustang donor car calipers, with stock rotors and pads. I'm using a single master cylinder, no boost.
Joel Hauser
Joel,
I am using sn95 mustang gt calipers and rotors up front and sn95 cobra in the rear. I went with G-LOC pads up front. I believe the G8 compound. After bedding them, the difference between those and then highest performance powerstop pads was unbelievable. Reduced pedal effort by 30% (not scientific but a very noticeable difference). On the rears I have hawk hp which I will eventually be switching to the G-LOC brand. I am using the Jeep master cylinder which is similar to yours and an sn95 pedal box from mike Everson with the pivot point changed.
I have used lots of different brands of pads in racing applications. After turning laps in the cobra with the g-locs I am impressed and happy.
