Began my build today by completing inventory. Only a couple of minor items missing
Many Thanks to Scott for expertly getting his 18 wheeler into and out of our gated community. He made a difficult task look easy. He allowed be to help with the unloading (basically made me check off boxes to keep me out of the way.
I was like a kid at Christmas
I have been reading several other build threads to try to avoid the pitfalls for beginners
Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022 Click here for my build thread
Serial #9158
How stinking excited where you to see that truck pulling up? I clicked on the order button today, I am sure I will get a call from them tomorrow to go over my order. Looking forward to reading your build thread.
Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
CVOBill
Inventory completed and missing in Kit order placed.
Front suspension assembly carried as far forward as possible till I reached the point of installing the hubs which are on back order. So switched to rear end. Ran out of parts again so had to pause here too.
