0
Electric Fuel Pump Location
Hey guys. Just ordered my 427 from Blueprint. Really looking forward to its arrival. Blueprint says that because I'm running power steering, that the front pulley system is not able to run with a mechanical pump, so need to go electric, which comes with the engine. That's a bummer as I already have it all plumbed out for a mechanical, but in looking for new routing, I've reviewed many posts around placement, and it seems that most put the electric pump behind the passenger 4" tube. I don't have the pump in hand, so can't actually fit it in position, but is this the best spot for an IRS rear end or is there somewhere else? I've seen one pic that looks likes the fuel line bows out a little too far when running down the passenger side 4" rail, but can't really tell from the picture. I'm not planning on running a return line, just tank > inline filter > electric pump > regulator > carb
