https://youtu.be/JAVexNcZmBE
My buddy Danny Johnson made this video of his Hot Rod Camaro and I playing around last Sunday.
Cool. If you ran just for lap times, which car was quicker? He seemed to pull away on the straights, but you caught him on the corners....
Turbo, that is his G meter. LOL
Rob actually my tires have a lot of heat cycles on them and it takes 3-4 laps now before I trust them. Our top speeds are almost identical, my corner speeds are higher. You will notice that once I get some heat in the tires or not leave it 4th for T2 he doesn't get a way. If I get held up in a corner his 530hp and 500+ftlb will pull a car length or 2 off the corner but I can go much deeper on the brakes, that shows the big difference between 3500lb and 1820lb . As far as lap times the 818 is 4+ seconds a lap faster fastest lap to fastest lap at NCM.
That's really impressive, Mitch. Funny you should mention heat cycled tires. I resemble that remark.
