I am looking for advice before I break out the SawsAll. I have a spinner stuck on a wheel that won’t budge. I was installing it for the first time. I removed the set screw. I spun it on to the cap to make sure it moved freely. Put cap in wheel and mounted the wheel. The spinner went almost all of the way on and would not go the last turn or two. It went easily so I’m sure it was not cross threaded. It turned easily coming off until the last couple of turns and then it froze. Won’t budge ether way now. I’ve tried heat, rubber mallet and cussing at it. Any suggestions would be appreciated. If I have to cut it off does FFR sell replacement center caps?
