Thanks Thanks:  2
Likes Likes:  2
Results 1 to 13 of 13
Thread: Battery Relocation with A/C
    Mar 2018
    Plano, TX
    It's only works with a smaller, dry-cell battery that can be laid on its side. I removed the hard-line coming off of the A/C evaporator and am going straight from the dryer/accumulator to the evaporator using the flex line.
    Gives a slightly higher center of gravity, but lets you route the a/c and heater lines easier and you won't hate yourself when it's time to change the battery. Plus, trying to mount the battery in the "recommended" location resulted in the possibility of rubbing against the steering linkage, which seemed like a terrible idea.
    Thoughts?
    IMG_20181012_220550209.jpg IMG_20181012_220541636.jpg IMG_20181012_220556434_HDR.jpg IMG_20181012_220606705.jpg
    Ryan
    GTM #511
    Build log: gtm.perkinsons.com
    Senior Member beeman's Avatar
    Indiana
    I love the idea of relocating the battery to a more accessible location, I am moving my battery as well (probably behind the passenger seat).
    If you are set on that location, I agree that you are raising the center of gravity, which won't matter a bit if your car won't be tracked. One thing to consider is switching batteries (can you return yours?) to a Braille battery like the B3121 which weighs 21 pounds and is the same price as your 49.5 pound battery.
    GTM #304 LPE 525hp LS3
    Mar 2018
    Plano, TX
    I might be able to return it, but I like how much battery I have. It might not be a daily driver, but it'll be driven on the street a lot. I'll look at the one you mentioned.
    I've been following your build.... you have a lot more patience (and space!) than I have, with all of that custom mod work!
    What parts are you throwing away to make room behind the passenger seat?!?
    Ryan
    GTM #511
    Indiana
    I moved the cabin forward so I have a bunch of room behind the seats.
    Jul 2014
    I'm thinking of mounting a Braille 3121 on its side in the location stated in the manual. Likely purchasing the sheet metal mounting box they offer. If was better with my sheetmetal skills, I'd make one. Keep the weight low. I'd like to get into some serious track days, and I figure any bit helps
    Have you guys seen what they get for the Micro Lite Lithium Ion options go for ?!?!?!?! HOLY SMOKES $2k for the ML30C
    Senior Member Presto51's Avatar
    Catonsville, Maryland
    Quote Originally Posted by Perkster029 View Post
    Thoughts?
    Hi Ryan,
    A little off topic, but I noticed that in your first picture where you have the rad over flow tank placed, and wonder if it's in it's permanent position?
    If it's temporary setting there, never mind, if it's in there for good, check it for clearance with the front nose if you don't mind?
    Ron
    Mar 2018
    Plano, TX
    Quote Originally Posted by Presto51 View Post
    Hi Ryan,
    Ron
    Hey, thanks for checkin! But we're good, I just moved it there to give me access. I'm installing the overflow in the stock recommended location
    Ryan
    GTM #511
    Mar 2018
    Plano, TX
    Quote Originally Posted by Shoeless View Post
    Super awesome how small and light that is!! Super not awesome how pricey that is.... Maybe Tesla's gigafactory will make some batteries for us!
    Ryan
    GTM #511
    Newcastle, Wyoming
    I also relocated my battery but it is setting upright with the coolant hard piping running into the tunnel under the battery mount. Just another idea, the battery shown is a bit larger than the AGM batter that will finally rest in the GTM so I know the AGM battery will fit. A couple of picture of that front battery area with larger radiator and 3000 cfm fans, hard piped cooling lines running under the battery mount.IMG_1907.jpgIMG_1908.JPGIMG_1909.jpg
    Mar 2018
    Plano, TX
    Quote Originally Posted by jamesfr58 View Post
    Nice! Did you build little "standoffs" that the battery tray rests on?
    Ryan
    GTM #511
    Jul 2014
    Hey jamesfr58, or anyone else that may know ,
    Where did you source the orange hard coolant lines in your third photo?
    Sean
  12. Thanks rolfer thanked for this post
    Likes rolfer liked this post
  13. #12
    Newcastle, Wyoming
    Yes I built them, they are standing off the existing frame
  14. #13
    Newcastle, Wyoming
    The hard piping was sourced form JEGS and painted a copper color to match my paint theme going forward. They do look kind or orange but they really are a copper color. Both the radiator end and the connections into the engine are hard piped with insulated hard pipe running through the tunnel. The picture of the tunnel show the line installed, the heater lines are hard piped and are hung in tubing clamps on the top with the heater lines under them. The AC lines are the gold insulated lines on the bottom with the electric e-brake.
  15. Thanks rolfer thanked for this post
