I have done the slick sand and 2K primer sequence and eventually sanding down to 600. However, when reading the sealer can it says to scuff with 180 prior to applying. Should I lightly scuff with 180, or apply the sealer to the 600 sanded surface? It does seem the sealer needs a slightly rough surface? Maybe Iím over thinking but any advice is appreciated!
