Thread: heater solenoid
    southern delaware
    heater solenoid
    i am trying to find out why my heater core is not getting flow. i have searched but not found a digram of fluid flow of the cooling system. the solenoid was installed with the labeled to "heater core" going to the core but i suspect since the other side goes to the expansion tank suspect the flow might be the other way. can someone please tell me which way this should be installed?
    Senior Member beeman's Avatar
    Indiana
    I believe that is the Vintage Air unit? Upgrade to the one from MyRaceShop
    GTM #304 LPE 525hp LS3
    Mar 2018
    Plano, TX
    There's a thread on the "other" site that might help, I actually looked it up yesterday for my build.
    https://www.ffcars.com/forums/42-fac...direction.html
    Ryan
    GTM #511
    Build log: gtm.perkinsons.com
    Indiana
    southern delaware
    thank you!!
    i am not very knowledgable about this system. can you tell me how yours is better? thanks in advance
    southern delaware
    fyi yes it is a Vintage Air unit and yes they had it in backwards and now it works!
