Factory 5 Brake Reservoir Dilemma
So I guess that at some point after 2015 and the 20th Anniversary kits were put out, FF changed the brake reservoirs from a 2" to a 3" and also changed up the caps to allow for air displacement. Does anyone have there 3" one that they did not use and would like to get rid of? I would like to replace my single 2" one, non-venting with two of the newer versions if I can get them. Feel free to PM me if you would like. I posted the quote below on the ask a FF tech forum and this is where I heard of the newer options. Thanks...
Originally Posted by
BadAsp427
I have a 20th Anniversary (#008) kit that I'm building. With that kit I received the chrome small brake fluid reservoir. My concern is that it seems to be a positive seal cap. If that is the case, how can fluid be sucked out of it if there is no displacement area (air) allowed into it? I understand that FF has changed this on newer builds? Is this something that can be upgraded with some new parts or something? I do not want to just "take the "o" ring out. I have to say, I'm very surprised that FF would want someone building this kind of car with this reservoir, seems kind of on the cheap side of things... I'm guessing it must work, either that or nearly everyone is spending money on the CNC double/triple reservoir system. Either way, Let me know your thoughts and what I should do. Thanks.
Attachment 95576
I most likely have a 3" one. I recieved the Type 65 kit in July. However, I will not be able to confirm and ship for another two weeks. Please remind me then if you have not found another.
Sigurd
I most likely have a 3" one. I received the Type 65 kit in July. However, I will not be able to confirm and ship for another two weeks. Please remind me then if you have not found another.
Thanks, will do!
Would also be interested in one.
This is what I received this from FF today when I inquired about the reservoir that has no vent. “ Carl, it actually works fine, you only want the reservoir about half full“
I’m not sure this is actually a correct statement as the MC is not going to suck a vacuum. Either way I would like to find some of the newer ones that are vented and have the rubber baffle.
