Fuel Line Fittings
Ok... What fitting do I need and where can I find it?
The BluePrint Engines Holley Carb came with the fuel line as seen in this photo. I'm not sure of sizes, but I believe this is an AN6 ??? I have installed the 5/16 hard fuel line that comes from FF. What I'm trying to find is the adapter that will come off of the 5/16 Hard Line and allow me to connect the braided hose to it. Ideally with a 90* elbow at the same time. (but I wont be picky) Can anyone help me?
If it's 5/16 inverted flare, that's a 1/2-20 thread. If your flex line is AN6, then this adapter will hook you up. https://www.summitracing.com/parts/rus-640600/overview/. Don't see anything in that combination that's 90 degrees.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
I FOUND THIS.. Is this what I need???
Originally Posted by
edwardb
Yup, I found it about the same time as you sent this... THANKS Paul...
Ok, all cleared up... just ordered both Russell 640600 and Russell 614806 Blue Anodized Aluminum 90-Degree Female -6AN to Male -6AN Adapter Fitting. Put those two together and I'll have a nice hook up for the fuel system.
BadAsp427
Sparkly shiny... Can't wait to get mine!
BadAsp427
Is that a Blue Print 427? My carb model has the fuel line on the passenger side and looks like this.
2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
ILPBFoot
Close... it is a BluePrint 347 and the fuel line is on the DS.... but it is 427ft/lb of torque... so I'm calling it a 427...
BadAsp427
You go Carl! I want to hear that first startup pronto!!
BadAsp427
Ah. Got it. A 650 Holley?
They are nice engines!
