Results 1 to 10 of 10
Thread: Fuel Line Fittings
    BadAsp427's Avatar
    Greeneville, TN
    Fuel Line Fittings
    Ok... What fitting do I need and where can I find it?
    The BluePrint Engines Holley Carb came with the fuel line as seen in this photo. I'm not sure of sizes, but I believe this is an AN6 ??? I have installed the 5/16 hard fuel line that comes from FF. What I'm trying to find is the adapter that will come off of the 5/16 Hard Line and allow me to connect the braided hose to it. Ideally with a 90* elbow at the same time. (but I wont be picky) Can anyone help me?
    If it's 5/16 inverted flare, that's a 1/2-20 thread. If your flex line is AN6, then this adapter will hook you up. https://www.summitracing.com/parts/rus-640600/overview/. Don't see anything in that combination that's 90 degrees.
    BadAsp427's Avatar
    Greeneville, TN
    I FOUND THIS.. Is this what I need???
    BadAsp427's Avatar
    Greeneville, TN
    Yup, I found it about the same time as you sent this... THANKS Paul...
    BadAsp427's Avatar
    Greeneville, TN
    Ok, all cleared up... just ordered both Russell 640600 and Russell 614806 Blue Anodized Aluminum 90-Degree Female -6AN to Male -6AN Adapter Fitting. Put those two together and I'll have a nice hook up for the fuel system.
    Senior Member cv2065's Avatar
    Sparkly shiny... Can't wait to get mine!
  7. Likes BadAsp427 liked this post
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    Is that a Blue Print 427? My carb model has the fuel line on the passenger side and looks like this.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by ILPBFoot View Post
    Close... it is a BluePrint 347 and the fuel line is on the DS.... but it is 427ft/lb of torque... so I'm calling it a 427...
  10. #9
    You go Carl! I want to hear that first startup pronto!!
  11. #10
    Cape Coral, FL
    Ah. Got it. A 650 Holley?
    They are nice engines!
