Results 1 to 16 of 16
Thread: Any Factory 5 cobras in wisconsin?
    Oct 2018
    Hey guys,
    I have been saving for a FFC for about 15 years and should be ready to push the button in early 2019. I was wondering if any of you have a FFC in Wisconsin that I could sit in. I just want to make sure this car will work for me before I place my order.
    Marc
    Maricopa AZ
    I know of a couple. How tall are you.
    Janesville, WI
    Hey Marc,
    I’m building a mk4 and I live in Janesville.
    Lake Mills, WI
    Martin here-Lake Mills WI. MK IV, receive 7.1.18 Coyote Motor TKO600, 3 link
    PM and we can chat.
    Apr 2018
    Colgate, WI
    Mike here in Colgate, you're more than welcome to stop over if you want to see one early in the process.
    Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
    Oct 2018
    Wow thanks for all the responses guys. I can see this fourm will be a great resource when I'm doing my build. Im about 6'2 180# so I think I will fit ok, but it will be great to actually sit in one so I can place my order with some confidence.
    Maricopa AZ
    You will fit fine.
    Senior Member LewPoberezny's Avatar
    Wauwatosa,Wi
    Oconomowoc if that helps. #8414
    Have a safe day,
    Lew Poberezny
    Wauwatosa, WI
    ____________________________________
    MKIV ordered Sept. 02nd 2010
    Stewert Delivered Oct. 11th 2010
    Order Forte's Magic Dec. 02nd 2010
    Roller Dec. 04th 2010
    Vredestin 245/45R17 Front 315/35R17 Rear
    See build details at my Blog
    http://ffr7347build.blogspot.com/
    Burlington, WI
    Where in Wisconsin are you located?
    Road Legal August 31, 2017
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    Quote Originally Posted by ffcobra View Post
    Yes you will fit fine. My son is 6' 2" and about 200lbs. He sat in mine last weekend and I have the seat one bolt forward on the Breeze seat mounts. I'm 5' 10". He was fine. With it all the way back plenty of room.
    I'm in Northern IL. Always welcome to come by to see my progress.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
    Wauwatosa,Wi
    Oconomow
    Quote Originally Posted by ThickCobra View Post
    Oconomowoc
    Have a safe day,
    Lew Poberezny
    Wauwatosa, WI
    Burlington, WI
    Quote Originally Posted by LewPoberezny View Post
    Oconomowoc
    I meant to direct my question of location to Marc, ffcobra.
    Jay
    Jun 2018
    South Central WI
    I'm in Verona and SlowLeak is just up the road from me with his near completed Coyote roadster. He was nice enough to show it to me and even take me for a quick spin. I am only 5'7" so there was plenty of leg room, but I do understand why some builders obsess over space for your feet. I occasionally fat-foot while shifting or braking in my donor Mustang and expect it will be at least that bad in the roadster. I can also imagine the passenger (my wife) wanting more space for her feet. Neither of these is worry enough to discourage me and once I finally have the kit in my garage, I can decide whether to just live with it or slightly enlarge the footboxes since my engine will be relatively small (302). Good luck, seems we have a good community of builders here in WI.
    Lake Mills, WI
    I'm in Lake Mills WI. private message me if you want to chat or set up a time to stop by.
    Martin
    Fairfax Station VA
    Quote Originally Posted by snowdave View Post
    By all means, expand the passenger foot box! It's not particularly expensive (~$200 in material at https://www.onlinemetals.com/merchan...76&top_cat=60; use 0.090 for floor if you're not satisfied with solidity of driver side), not particularly difficult (use cardboard to get the size & shape of panels right), and if you screw up easy enough to replace the bad panel. Take a look at Post #179 of my build log (https://www.ffcars.com/forums/17-fac...-build-10.html) to see what's involved.
    MK IV Roadster #8631
    Feb 2017
    Waterford, Wisconsin
    Mike here in Wind lake...MK4 completed...
    2017 MKIV, 347 EFI Blueprint - TKO 600 - 3-link, Delivered 4/17/17 - At painter 2/15/18
