Results 1 to 7 of 7
Thread: Power Steering Fluid Capacity?
    Member JETAV8R's Avatar
    Apr 2018
    Wilson, NC
    Getting very close to the first start. As soon as FF sends me a backordered radiator. Does anyone remember what the fluid capacity of the power steering pump and rack is?
    Louis
    Cape Coral, FL
    Louis,
    Just installed mine and filled it for first start. Ran it, turned it off and added more. started a couple times and did the same with no steering wheel movement. Then turned the steering wheel lock to lock and have refilled. Took about 3/4 of a quart. Note: I'm using AN lines from the rack to pump, not the ones supplied with the kit. They make take a bit less fluid.
    Cape Coral, FL
    And FYI, the coolant system took exactly 4 gallons with getting all the air out and have a larger overflow tank 1/4 full.
    Apr 2018
    Wilson, NC
    Thanks Steve. Just what I was looking for!
    Jax Beach, FL
    The best way to fill a rack is with the engine off. Jack the front up, fill, turn the wheels full lock each way until there are no more bubbles and the level stays steady, filling as needed. You aerate the fluid less that way.
    Then run and re-check.
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    That's exactly what I did to fill mine.
    Build 1: Mk4 Complete Kit #9312 Ordered 1/27/18, Delivered 3/24/18, CA SB100 Registered 9/11/19 - Gen 2 Coyote TKO600, IRS, Power Steering, Wilwood Brakes, 17" Halibrand.
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
    Cape Coral, FL
    Great tips guys. Thanks. I had no issue with any foaming. Maybe the Motorcraft Type F fluid? it is very resistant to foaming.
