Will this be the last of the wiring?
I got to the point where a number of things that I wanted to do required some wiring to be completed under the body, needed to take the doors apart to get the power window components in there, needed power window wiring completed,... So, all the body components were taken off and I'm back to chassis only again. The intention is to build it up this time so everything is totally functional and will either get it legal or do the final prep for a body shop.
With the body off, I finished fitting and wiring the gauges and added the AC/heat vents to the sides. For the wiring, I took out the wires that weren't needed and shortened up numerous others. Still need to secure the indicator light wiring a bit better
Finished off the wiring around the tranny tunnel to get ready for a center console. The wire bundle going towards the rear is for the power window switches and the bundle more forward are for the stereo. Still need to figure out how clean up that ball of wire that will be behind the dash.
Lastly, I needed to add switches to the doors to activate courtesy lights and also needed to add a relay for the door popper on each side (negative activation pulse comes from the Digital Guard Dawg PBS-II system). This pic shows the wiring on the driver's side.
Gen 1 '33 Hot Rod #1104
