Thanks Thanks:  2
Likes Likes:  27
Page 2 of 2 FirstFirst 12
Results 41 to 63 of 63
Thread: #1104 Steve's 33 Rod Build
    Jun 2018
    North Vancouver, BC, Canada
    Driver's side IRS done.
    Seasoned builders, please let me know if you see anything that doesn't look quite right.
    BUILD TIP: Take the spindle and trial fit it to the LCA and toe adjustment arm first before putting the CV axles in place. It's much harder to spread the mounting tabs to fit the spindle while having to hold the CV out of the way. Once you've got the tabs spread apart enough then put the CV axle in place and connect the LCA, etc permanently.
  2. Thanks erlihemi thanked for this post
    Likes Chris C liked this post
  3. #42
    Aug 2018
    Since I didn't go to the build school, I really appreciate these tips! Keep em coming.
  4. #43
    Jun 2018
    I've been working on the front suspension, a lot of powder coating to do. Will post a pic or two when it's all together. BUT, in the mean time, I picked up the wheels & tires today. Super pleased with how they look. Went full on for the rears, 18 x 11 with 315s. Tony confirmed it should fit but man it's going to be close.
  5. Likes wrp liked this post
  6. #44
    Simi Valley, CA
    Nice looking wheels! What are they?
  7. #45
    Jun 2018
    Thanks! Cant tell you how long I agonized over the decision. Anyone else make lists of options in word or excel day after day? Valvecovers were even harder. Anyway, these are Foose Coupe F238
  8. #46
    Senior Member TDSapp's Avatar
    Frisco, TX
    Yes! I have a spread sheet with multiple tabs in it for my build. One tab was for nothing but wheels and tires, photos of cars with tire specs, links to web sites, and prices and sizes. Took me over a year to finally figure out what I really wanted. I now have the tires waiting on the wheels, which have been ordered and I am just waiting on them to be delivered.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  9. Likes FF33rod liked this post
  10. #47
    Jun 2018
    okay, busy time of year with family and friends. I'm kinda the main cook in the family, at least for large family feasts so there hasn't been a ton of time for the rod. The front suspension is all powder coated except for the upper arms as they are too big to fit into the Eastwood oven. So I've moved on to other things including working on the firewall. Some interference in fitting the 3 firewall pieces - the welds are bulging out in the odd spot.
    Here's a pic of the lower firewall, drive side. Note how it can't sit flat against the frame.
    here's a couple of pics with the interference areas circled
    So some grinding is necessary. Also put a chamfer in some areas of the aluminum to help with the fit, rather than take away more of the weld.
    Fits much better now
    Using a laser level to ensure everything is symmetrical, first leveled out the chassis and now marking the firewall pieces so they end up mounted level as well.
  11. Likes Chris C liked this post
  12. #48
    Aug 2018
    It's interesting to see what parts you didn't get vs mine, since we got our cars delivered(1102) on the same day. Scott just stopped by and dropped off my new roof and waterfall this morning. Looks much better than the first one.
  13. Likes FF33rod liked this post
  14. #49
    Aug 2018
    Does your frame have the straight top rail in the door opening, or does it drop down in front like the Gen 2 design? Mine drops like the Gen 2, but the body and floor panels are Gen 1.
  15. #50
    Mar 2018
    Yucaipa, CA
    I have #1095 delivered mid Sept 17' and the chassis Has the drop door opening but the body does Not. I am not near the body work yet but planning ahead I think I will cut the fiberglass and make my body match the chassis. I am not an expert at glass work but have done a little in the past. ALSO, I notice the newest version of 33's have functional louvers on side engine panels. Always liked louvers and considering adding them to my side panels but have no idea how to get there. Yet. They can be only cosmetic but functional would be nice too. Any ideas out there? I have done internet search and found very little, at least in fiberglass. I guess I could get new side panels if they are available.
  16. #51
    May 2016
    North of sacramento Ca.
    They work very good to get heat out, was going that way but now have opening under and around turbos.
  17. Likes wrp liked this post
  18. #52
    Jun 2018
    Quote Originally Posted by Chris C View Post
    Frame drops at the door but like yours, body is Gen 1
  19. #53
    May 2018
    I asked FFR and they told me that louvered side panels are planned for the 32 and 33 style grill. No availability date yet.
  20. #54
    Jun 2018
    So the holiday season is behind us along with a quick vacation to mexico, then a biz trip, some family birthdays, and finally I have some time to spend with my mistress (that's what my wife is referring to the 33 as these days).
    Build Tip: drilling the firewall After marking up and then drilling the firewall you will place the firewall panels back on the frame and clamp them in place ready to drill into the frame. Only drill a couple of holes, and then install clecos (or button heads if that's what you're using) to hold the firewall while you drill the remaining holes. The clecos or screws hold the panel much firmer than a clamp that may allow some slippage.
    I've finally finished powder coating all the front suspension, have installed the front spindles and brakes and test fit the wheels. Feeling good about this!
  21. Likes AJT '33 liked this post
  22. #55
    Aug 2013
    Gatineau, Quebec, canada
    Would suggest that you flip your fronts 180 degrees if you intend on adjusting them or they will be a PIA to adjust.
    PS. Clecos are my best friend!
  23. #56
    Senior Member JOP33's Avatar
    Haslet, Texas
    I believe these are the KONI DA’s and if so they can’t be flipped (or at least what I was advised by FFR on mine).
    33' Hot Rod Coupe/Roadster, Fenderless (Maybe), Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18
  24. #57
    Aug 2013
    Quote Originally Posted by JOP33 View Post
    I believe these are the KONI DAís and if so they canít be flipped (or at least what I was advised by FFR on mine).
    These are mine and don't seem to be the same so you may be right, I would also suggest asking FFR or contacting Kioni direct. I know that mine can be flipped over.
  25. #58
    Jun 2018
    You are correct, these are the upgraded shocks (dual adjustable) and you can mount them one way only - with the body down.
  26. #59
    Jun 2018
    Brake lines are in along with steering rack, shafts, electric power steering, column and wheel.
  27. #60
    Jun 2018
    Steering Wheel adaptor interference
    So when I put the steering colum in place and added the steering wheel with adaptor, the wheel wouldn't move. The adaptor tightened down right onto the column with no space as shown in the first picture below. The second picture shows the top of the steering colum that the adaptor goes onto. What is needed in some cases is a washer. I picked up a 1/8" thick rubber washer with an inside diameter hole of 3/4". Cut out a space for the horn button contact and installed as shown in pic #3. Last picture shows the steering adaptor and wheel back on with a bit of a space now that allows movement. This is a good thing
  28. #61
    Jun 2018
    Fuse panel location
    I stared at the fuse panel mount and the description in the manual of where it should be installed. Not sure why but it just didn't click initially although it's simple and makes sense. Here's a couple of pictures showing the install so anyone else tripping through this thread will have the visual. Also note that for the hot rod you do not use the aluminum mount for the fuse panel that comes in the Ron Francis wiring box - discard that and use the one that is found in the box of aluminum pieces for the hot rod. Note that I have installed replicaparts' inner firewall which shows in the pics.
  29. #62
    Jun 2018
    Examine your fuse panel when installing
    I was perusing the panel before installing it in the aluminum frame and I discovered a wire that had pulled out of its crimp. A quick solder job fixed it but have a look before installing to make sure yours doesn't have any similar issues...
  30. #63
    Aug 2018
    You've been busy!
    I've been talked into fitting the body and panels first, before putting all the shiny parts on. It's the crappiest part of the build, so if I do it first I hope not to burn out on it later.
