Driver's side IRS done.
Seasoned builders, please let me know if you see anything that doesn't look quite right.
BUILD TIP: Take the spindle and trial fit it to the LCA and toe adjustment arm first before putting the CV axles in place. It's much harder to spread the mounting tabs to fit the spindle while having to hold the CV out of the way. Once you've got the tabs spread apart enough then put the CV axle in place and connect the LCA, etc permanently.
Post Thanks / Like - 1 Thanks, 1 Likes
