Results 1 to 5 of 5
Thread: brake stop for Wilwood Pedal box
    Lake Mills, WI
    Guys,
    Do you need a hard brake stop on the wildwood pedal box?
    I have one for the clutch.
    If you need one for the brakes , Does anyone have photos of their brake stops on the wildwood pedal box they could share?
    Martin
    May 2016
    North of sacramento Ca.
    No stop on brake.
    Just a throttle stop - nothing on the brakes or clutch (cable actuated).
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Oct 2017
    I did an adjustable stop for the clutch that limits how far the pedal comes up.
    Quote Originally Posted by magicmarto View Post
    Guys,
    Martin
    Certain clutches required a pedal stop to prevent over travel and damaging the clutch. Nothing on the brake. On throttle I use a variable rate linkage and no stop.
