Could anyone help me with the set screw size for the upper steering shaft bearing/mount? There was a little in and out play with my steering shaft and I found that the set screws are no longer there. The builder drilled through both shafts and installed a cotter pin which is why the upper shaft did not pull out but moved about an 1/8 - 1/4".
Also, my upper mount is installed opposite of the drawing in the build manual. The set screws are on the engine side, the manual shows them on the steering wheel side. Probably just for access but I'm not positive. I haven't built one of these for a long time so I can't remember.
