Thread: SBF pulleys and alt brackets
    wallace18's Avatar
    Trenton, Florida
    I am putting together an MK4 for a customer. He has a Ford Racing X302B crate motor. I need pulleys, brackets and belt for just an alternator. Anyone have part#'s or vendor that sell this stuff? Thanks. TW
    Senior Member Norm B's Avatar
    I used CVF racing pulleys and brackets. Great products at a good price. Can be found at cvfracing.com. You can choose either serpentine or V belt in polished aluminum or black finish.
    HTH
    Norm
    Jun 2018
    X2 on CVF
    Rotonda West Florida
    March performance here, mostly because they put the a.c. On the passenger side.
    Nov 2016
    "The i.e." SoCal
    I'd call Mike Forte.
    wallace18's Avatar
    Trenton, Florida
    Thanks Guys! all good suggestions I will follow up on.
    Mar 2013
    Medway, MA
    I'm fairly certain that Breeze is the only company that offers a serpentine crank pulley in stock diameter that fits the Ford Racing Hi-Po damper and does not need a spacer to align the belt at the stock Mustang 5.0 distance from the block.
    https://www.breezeautomotive.com/sho...hipo-balancer/
    Tom - I've sent you an estimate for everything except the stock steel Mustang 5.0 water pump pulley which you can find used and refinish. This combo gives the right water pump and alternator speeds for a street driven car.
