I am starting to work through how I want to have my dash laid out, both for function and aesthetics. I am trying to look through pictures of what others have done but I haven't found many of dash layouts. My thought right now is to have the Tach and Speedometer centered above the steering wheel and my other 4 gauges to the right of the steering wheel. I would assume ignition switch and AC controls to the right of the steering wheel. Maybe have the headlight switch to the left of the wheel. Where do others have turn indicator lights, or the high beam indicator light. I think as far as the dash is concerned the only thing I would need to be able to touch while driving is the headlight switch, and the AC controls (trying to make sure they will be within reach with belts on). The turn signals will be on the column so should be easily reached.
Any tips from those that already have everything set up or things they would do differently? I am really apprehensive about drilling into the dash so I am trying to think through the placement.
