Likes Likes:  2
Results 1 to 16 of 16
Thread: 818R Track/Race car
Threaded View
    Bowling Green, KY
    818R Track/Race car
    Factory Five 818R Track/Race car, Chassis 145 delivered August 2014 completed August 2016. This car is well sorted, quick and big fun to drive. I built the car to be dependable, light, and easy to work on and easy on consumables.
    Specs:
    • Black power coated chassis
    • Stock 2.0L EJ205 with VF37 JDM twin scoll turbo, JDM EL header, 1000cc injectors, Cobb Boost controller, Killer Bee wet sump, OCV and pick-up, ArcTangent Design Oil Control Plate, Crawford AOS. 2 mild tunes 256whp and 285whp on pump gas Tuned by Corbin Johnson. STi TMIC with relocated IAT sensor, TGV Delete, 9.5lb ACT Flywheel and Clutch Disc OEM Pressure Plate and T/O bearing.
    • Iwire harness, 2004 WRX ECU, AIM MXL dash, 10lb Fire system, 15gallon ATL fuel cell, 6 Point harness, removable steering wheel (Momo)
    • AP Brakes front and rear, Wilwood pedal box.
    • 2004 WRX 5 speed, Cusco 1.5 RS Limited Slip
    • 2004 WRX Donor, Aluminum LCA, All hubs received new bearings when the car was built.
    • 17X8 TSW Front Wheels Enkie 18X9.5 TS9 Rear Wheels, BFG R1S tires
    • Adjustable front swaybar's .065, .095 and .120 wall .75 4130.
    • MR2 shifter with Zero DB shift linkage
    • Car Scales at 1850lb W/O Driver.
    • Body is polished red Gelcoat.
    • Build thread https://thefactoryfiveforum.com/show...ct-has-arrived and some on-track video here https://youtu.be/JAVexNcZmBE https://thefactoryfiveforum.com/show...Open-Track-Day
    SOLD
    Mitch Wright [email protected]
    September 15 2018-105 T13 2.jpg818 3-4 front LS.jpg3-4 front.jpg3-4 rear 818.jpg
    More photos available on request.
