Results 1 to 5 of 5
Thread: Body fit question
    Accord NY
    Body fit question
    I have the body on with the bulb seal on. Do many people need to trim the rear cockpit wall? As you can see the bulb seal sticks out below the body?. It’s worse on the passenger side. I did also install the quick jacks and that has not helped.
    Elk Grove, NorCal
    Im not at that point yet in my buid yet. However, i think it is recomended to not put bulb seal at that locaation just for that reason.
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
    Accord NY
    Without the bulb seal the body has pretty even spacing against the rear cockpit wall. I’m curious if as you add the trunk, hood, splash gaurds etc... does that help with the fit in other areas.
    Alliston, Ontario, Canada
    Build seal does not go on the rear cockpit wall between the trunk walls. Do a search you’ll find plenty of info and pics. Leave it on the rear wall from the trunk side walls down to the door latches, take off the middle section between the trunk walls.
    Accord NY
    Thank you both!!
