Thanks Thanks:  76
Likes Likes:  47
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 252
Thread: Redbone Has Graduated / The Official Dark Side Build Thead
  1. #121
    Hey Steve
    I'm a bit behind you (let's call it a month or so) on my '33. Heavily into fitting the doors, engine side covers, etc and then I'll be into knocking down the mold flash, etc.... It would be great if you posted more details on your approach and methods here. I know you'll be following the advice of the body "wise men" so it will be good to get it out there again. So far I've got some Dura-Blocks and just ordered some Soft-Sanders, also have a gallon of the Rage Gold, a roll of 80 grit for the initial rough stuff,....
    For the record I'm going very slow with the sanding and take breaks when I get frustrated since I'm A 100% Body Work Virgin!
    I knocked the parting lines down with a 2" Mini D/A.
    https://youtu.be/_3sLamdkIFg
    Next I went after it with my 5" D/A.
    https://youtu.be/meBYeI96_A8
    Now I'm using my Dura-Blocks and Sanding in an X-Pattern plus using a Black Guide Coat to expose any low spots.
    I'll start using the Rage Gold & Fiber Tech body fillers, both are Evercoat products, once I'm happy with the body.
    Before I apply any filler I'll degrees the body, and rough it up with 80 grit once I have the low spots identified.
    Hope This Helps!
  2. Thanks FF33rod thanked for this post
  3. #122
    Looks very meticulously done, Steve. I can't believe how much nicer your body is than what I got with my kit. Keep at it and keep the progress reports coming.
  4. Thanks GoDadGo thanked for this post
  5. #123
    Jun 2018
    North Vancouver, BC, Canada
    Man if the 33 body only looked that good to start with. Once I knock down the mould flash, there is no way I can go to blending that in with the surrounding area - huge divots and such. So will have to start using some filler right away at that point. Anyway, this is helpful, Thanks!!!
    Gen 1 '33 Hot Rod #1104
  6. Thanks GoDadGo thanked for this post
  7. #124
    Dave,
    Jeff and I have discussed the quality of my body versus others like yours on several occasions.
    Having built more than a few fiberglass boats in my youth, it pains me to see shoddy glass work.
    Mold preparation (waxing & buffing) seam sealing with the modeling clay and final mold alignment are all necessary to get good parting lines.
  8. Likes RBachman liked this post
  9. #125
    The Body To Frame Fitting Is 100% Done!
    1. Body Is Mounted & In A Very Repeatable Resting Location.
    2. Doors Fitted With A Slight Under Gap.
    3. Trunk Fitted With A Slight Under Gap.
    4. Hood Fitting Is Going Slower Than Anticipated.
    Now I'm itching so it's time for a vinegar wash down and shower.
    Man I hate the smell of that stuff, but hate itching even more.
  10. Likes FF33rod liked this post
  11. #126
    On a roll Al_C's Avatar
    Wheaton, IL
    Just reading this now. I'm confused: who's getting the vinegar wash down - you or the car???
  12. #127
    If you are itching to the point of no return, wash yourself down with vinegar and it will reduce the itching.
    If you are doing glass or insulation work, it really helps cut down on the scratching.
    For the record I hate the vinegar, but hate itching more.
  13. #128
    The body work is going rather slow because I'm pretty much living at the office most days and weekends too.
    I will likely be getting my friend Sammy to either assist me or I may bring the car to his place.
    He's been my friend Ernie's right hand man at Dependable Paint & Body for 31 years.
    Man I hate bringing in help, but the car needs to be painted and finally done!
    Shown below is an example of what the Sam-Man can do so What-Cha-Think?
    https://youtu.be/A5WUZgl6N5Q
    "Ugh, Ugh, Ugh!" Said Charlie Brown!
  14. #129
    RJD's Avatar
    Northern Virginia
    Looking good. Love the mirrors.
  15. #130
    Steve,
    There is no shame in asking for help to achieve your goals. If you have resources available and that get's you to your goal, go for it!
  16. #131
    Tybee Island, GA
    Someone told me once, "Are you going to keep the car? If so, what's the difference in the long run if the car is done 2 months later than what you wanted?"
    Point is, we put timelines on ourselves that sometimes don't take in all variables. This helped me when I needed to go back and fix something I had initially done wrong, or was hit with a setback.
    If you truly hate bringing in help, and if it's going to eat at you because you had a goal of completing everything yourself, then be patient. But I agree with Papa, someone else working on the car with you or for you would be a great way to get the project over the hump and done.
    You've done a fantastic job on your dark side build, and you've had several setbacks that you've overcome. It's definitely in you to complete it.
    Best Regards,
    Videos are at: YouTube Videos
  17. #132
    Thanks Dave & Dave,
    The Sam Man Has Been Called!
    He'll be meeting me tomorrow around 12:00 Noon assuming I get home from work by then.
    Thanks Again Double Daves!
  18. #133
    Quote Originally Posted by RJD View Post
    The mirrors are for a 356 Porsche.
    Shown below is where I got them.
    https://sierramadrecollection.com/35...T5-p20310.html
  19. #134
    O'Fallon, MO
    A man's got to know his limitations .
  20. Thanks GoDadGo thanked for this post
  21. #135
    Amen Brother!
  22. #136
    Enter Sam Man!
    We've made great progress on the bodywork with all of the mold parting lines smoothed, filled, blocked and trace coated.
    Thankfully the body we are working with is excellent compared to most we've seen on the forum in recent years.
    Our next phase will be to attack the doors, specifically where they meet the dash cowling intersection area.
    The Sam Man (Samuel Olsen) is doing an excellent job and he is truly an excellent teacher too.
    The Expert Advice Given To Us By Jeff Kleiner Has Really Given Us A Huge Leg Up For This Phase Of The Build!
  23. Likes Papa liked this post
  24. #137
    The Car During The Summer:
    https://youtu.be/CaRlqMmKIzk
    Mold Parting Line Knocked Down:
    Mold Parting Line Smoothing:
    Mold Parting Line Filled, Blocked & Smoothed:
    https://youtu.be/6QXWP5H8mT0
  25. Likes shmelty liked this post
  26. #138
    Looking good, Steve!
  27. Thanks GoDadGo thanked for this post
  28. #139
    We've been busy with body work so we are now knee deep into getting Redbone ready for the it's War Paint.
    Split & Fixed The Drivers Door Plus Door Cowl Work:
    https://youtu.be/6UK6K2jcwTU
  29. Likes FF33rod liked this post
  30. #140
    We're in the home stretch now and are working on the doors.
    We hope to be in the paint booth in a few weeks.
    The goal is to be the flavor of CSX-3178.
    The color will be Dodge Torred.
    Link To CSX 3178 Pics :
    https://rmsothebys.com/en/auctions/m...sx-3178/380123
    Link To CSX 3178 Sale From 2016:
    https://youtu.be/FJpASOjJWa8
    What my car looked like before we blew it apart to do the bodywork:
    https://thefactoryfiveforum.com/albu...hmentid=105129
  31. Likes FF33rod liked this post
  32. #141
    Dec 2012
    Houston, Texas
    Link To Pics:
    Link To The Sale From 2016:
    What the car looked like before we blew it apart to do the bodywork:
    Go Dad Go! (Probably for the thousandth time)
    Phil: FFR 3121, Frame #2050, Mk 1.5, built 2002, 1991 donor with Blueprint 302 long block and 1993 Cobra intake, BBK 70mm T/B, no smog, power steering, T-5 and 3.55 rear.
  33. #142
    Quote Originally Posted by ptstew View Post
    Thanks for the support.
    I also ordered a new pair of headers on Friday because I think I can do a better job getting the angle on the dangle looking better with a new set.
    Currently I've got some Breeze Wedges in place and would like to avoid using them if possible.
    At $200.00, it is a small price to pay for a set of headers.
    The Part Number Is IMCA Modified Adjustable 161-33.
    https://www.schoenfeldheaders.com/im...modified5.html
  34. #143
    The Sam-Man Worked Solo Social Distancing Yesterday So The Body Work Is Now Complete Except For The Gapping!
    That means I had a Gapping Good Time until my fingers got a bit torn up so I had to call it a day.
    Right now I am just under 3/16" (Thick Paint Stick) on the hood and doors.
    I hope to get after the trunk one evening soon.
    My O.C.D. Gene Is Making Hand Sand The Gaps For The Final Fit!
  35. Likes Ducky2009 liked this post
  36. #144
    The Door Gaps Have Been Perfected, Yeah!
    ..........Next is the hood and finally on to the trunk.
  37. #145
    [SIZE=3]...
    Steve my friend,
    3/16” dry (i.e. before primers, paint and clear) is gonna’ be tight once everything is on it, especially at the leading edges of the doors and trunk.
    Consider yourself warned
  38. Thanks Kmcallahan thanked for this post
    Likes Kmcallahan liked this post
  39. #146
    Steve my friend,
    After nearly four (4) hours of sanding, the doors are re-gapped per your recommendations.
    I'll get after the hood and trunk after lunch.
    Thanks As Alway!
  40. #147
    We Are Done With The Bodywork So We Are Ready For Paint!
    .........The doors, hood and the trunk have all been properly gapped.
    No Saws; Just Sanding & Sanding, But Well Worth The Effort!
  41. Likes egchewy79, Jon liked this post
  42. #148
    Ancaster, Ontario
    Steve, if 3/16” is insufficient, how much gap did you use? Consistently throughout?
    Joe
  43. #149
    Quote Originally Posted by Joecobr View Post
    Joe
    Joe,
    I'm a smidgen past 3/16" on all of my gaps, but still under 1/4".
    It wasn't easy, nor fun to do them all by hand, but the gaps are extremely uniform.
    Using one gauge and a lot of patience really paid off for this part of the build.
  44. Likes FF33rod liked this post
  45. #150
    The Redbone Roadster Is Ready For It's War Paint!
    Final Video Before It Gets It's Color!
    https://youtu.be/po1Bb2_XDDk
  46. Likes Fman liked this post
  47. #151
    Looking good Steve! Now you'll move on to the next phase...high build primer (Slick Sand or painter's preference) then blocking it followed by 2K primer surfacer and blocking that. Oh, you didn't think the sanding was over did ya'?
    Sir Jeffski,
    The sanding is over for me at this point in time.
    The body will be going to Dependable Paint & Body where Sir Sammy will tackle that aspect of the process before handing it off to their painter.
    https://www.collisionrepairslidell.com/
    The big question is will Sir Ernie (The Owner) insist on doing the final spray out since he truly is the best of the best and only tends to do the custom stuff.
    Can't Wait Because This Has Been Too Darn Long To Get To This Point!
  49. #153
    Elk Grove, NorCal
    Looking real good Steve. Can’t wait to see it painted.
    Kit purchased: July 25, 2017
  50. Thanks GoDadGo thanked for this post
  51. #154
    Jun 2018
    Looks good Steve. I particularly like how you addressed to door problem.
  52. Thanks GoDadGo thanked for this post
  53. #155
    Quote Originally Posted by Vspeeds View Post
    Quote Originally Posted by Tony_G View Post
    Thanks Gentlemen,
    The body goes to the paint shop on Monday so I'm pumped.
    Also, the driver's door issue was making me go nuts so I'm hoping my solution gives other builders an alternate solution for that problem.
    I just wish they'd do a better job with their current glass work because My Body Was Great compared to what I'm seeing on the forum lately.
    This Video Made Me Choose Factory Five Racing:
    https://youtu.be/6ckgfkPU8Ss
  54. Likes Ducky2009 liked this post
  55. #156
    The Redbone Roadster Got The Body Pulled & Raptor Bedliner Applied!
    https://youtu.be/FVMCA4_UZHU
    If you like Herculiner, you'll absolutely love this stuff.
  56. #157
    To The Bodyshop We Will Geaux!
    My pal Ernie opens at 8:00 so I will be showing up about 30 minutes later.
    He opened Dependable Paint & Body when I was 16, the real problem is that I'm now 57 and Ernie is 68.
  57. Likes 65 Cobra Dude, GTBradley, RBachman liked this post
  58. #158
    Port Charlotte, FL
    Congrats on getting to this milestone!!! Good luck sleeping tonight Steve!
    Henry
  59. Thanks GoDadGo thanked for this post
  60. #159
    The car has been blocked and prepped so tomorrow it enters the spray booth to start the painting process.
    It will get blocked two or three more times before it gets any color.
    To say the least the car is getting a lot of attention.
  61. Likes Fman liked this post
  62. #160
    I'm excited for you, Steve.
  63. Thanks GoDadGo thanked for this post
