Help Posting Photos
In the most recent upload of pictures to My Album, some photos are turned sideways. Is there a way I can fix them so they will be right side up when I post them in a thread?
Also, Is there a way to size them in order that the viewer doesn't have to use the scroll bar to view the whole width of a photo?
Finally something I can answer! woohoo,
Hey Bob, I had the same issue. If the photo is taller than it is wide it will auto rotate sideways. The best way to load photos is found in this thread
https://thefactoryfiveforum.com/show...David+hodgkins
Once you get the hang of it it is so much easier. To resize the photos BEFORE you upload them to the album will depend on what type of computer you are using. I'm on a Mac so I can select all the photos and resize them at once. I go with 800x600 most of the time. Makes the upload time quick and the pictures can be seen in one frame easily.
Good luck!
"Doddmoore," Mitchell Moore on facebook, Follow Tonks347Cobra on Instagram
MK IV Complete kit, SB Ford 347, Holley Sniper EFI, TKO 500, Moser 8.8 Solid axle, Wilwoods, Power Steering
My Build Thread:
Tonks347, The Baker's Build
Slow and steady wins the race.
