Is there a better throttle cable assembly available than what comes with the G3 Coupe kit? Mine gets heat soaked and then starts hanging up. Insulation just delays the heat soak. It seems the plastic lining inside the cable housing gets soft and starts adhering to the cable. A cable housing w/o the plastic lining would probably work well, but I can't find such a thing. Thanks.
