Thread: Race car Wiring Diqagram Help Needed.
    East Hartford, Ct.
    I need a very basic and I mean Basic, wiring diagram for my car. What is the power path and what are the fuse and relay requirements. If I can pay for a My Car Specific diagram I will but I'm hoping for the generosity of someone who has the time and wants to help. I have the dash harness in place and the Megasquirt computer is connected to the engine. I need to know how to go from the battery to everything.
    What about 5v?
    Does 12v go from the ignition switch then to a resister that sends 5v to the switches and then everything that needs 12v has to go through a relay?
    Does 12v go from the ignition switch to the fuse panel and relays?
    Does 12v go to the gauges for sensor power or is that 5v? With 12v, when I start the engine the oil pressure goes right to 100psi
    If you respond, please use baby talk as I don't speak Electric.
    The following is what I need to power.
    Equipment
    Starter
    Solenoid
    Fuse Panel Main Fuses?
    Relays
    Megasquirt ECU
    Resister to 5V?
    Switches
    Ignition
    Fuel Pump
    Gauge Lights
    Coolant Fan
    Momentary Starter
    In Line Brake switch
    Strobe Light
    Ground Kill Switch
    VDO Gauges
    Tachometer
    Water Temp
    Oil Temp
    Oil Pressure
    Volt
    Clock
    Thanks, Jack
    Senior Member weendoggy's Avatar
    Aptos, CA
    I can send you a couple of simple chassis diagrams if you're interested and then if you need help, we can go from there. You have some redundant items in your list that can be consolidated. Not sure why you want a 5v circuit. Bottom line would be what are you intending on running with a relay and then go from there on what/how to wire them and what they'll power.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
    East Hartford, Ct.
    Thanks for getting back to me. You have to keep in mind I know Nothing, OK, very little about wiring and What I need. I have it wired now with everything working, except the brake lights for some reason, but I want to make it better. I'm going to sell this car as a 1971 "Race Car" replica that can be driven the way it is or they can "Restore" it and make it better. You can e-mail me at [email protected] You can see my videos and read my comments at my YouTube channel. JB91710. Click on Videos at the top of the page.
    Bob was generous enough to share some of his work and simplified wiring diagrams with me here....
    https://thefactoryfiveforum.com/show...dieting-advice
    Maybe have a look and see if you can find what you need.
    Sacramento CA
    Usually, 5v comes from the computer for sensors that use the 5v for feed back to the computer. I assume if the MS gets 12v you will have the 5v out of it?
