Results 1 to 5 of 5
Thread: Under nose aluminum with carbon splitter
    Saline, Mi
    Manual says to not use the front nose aluminum ( with deflectors) if you use the front splitter cause it will
    cover the floor. That is obviously not correct but what have most people done. You can cut up the supplied
    piece and rivnut to splitter or ...
    Seems i remember some using the nose piece under engine and bending the deflectors to exit under engine
    air. Did I remember that correctly?
    Mounted front splitter. Looks good.
    frank
    Bowling Green, KY
    I didn't use the lower aluminum panel with the splitter.
    Senior Member EODTech87's Avatar
    Feb 2013
    Copperas Cove, Texas
    I purchased some aluminum and am going to cut a piece that will go from the front splitter to the front firewall.
    -Jason
    Saint Charles IL
    I would be curious to see what some have done regarding the aluminum and how they mounted their CF splitter.
    Saline, Mi
    Quote Originally Posted by axelthrasher View Post
    Ask and you shall receive. Just finished sealing off nose with alum today and cutting down nose floor a little to mount to bracket in front the carbon splitter mounts to. Pictures attached.
    You can see some of mounting bolts
