Likes Likes:  2
Results 1 to 19 of 19
Thread: Fender flare feedback
    Jul 2014
    Strathroy, Ontario Canada
    So I have started a "small project for the car. I am on the fence for the look I have. I need feedback on the gender flares I have made. The wheels are just sitting in place as I would need to buy new wheels with the right dimensions. The flares I made are liberty walk inspired . These are rough templates to see if it
    will look good. I might clean them up and hit them with primer to get a better idea. I look forward to everyone feed back.
  2. Likes Zach34 liked this post
    San Diego Ca 92106
    I like what your doing. The front flares look great so far. On the rear since your there and if your inclined to, and had the thought of widening the side scoops, you might try to extend the flare to the line over the side scoop under the gas cap and keeping the same angle, extend the edge of that line to the ledge of the rocker panel. If that makes sense . This way you can do two things with one part.
    Just something to think about.
    Jul 2014
    good point, I will run some tape and lines and see how it looks. here are a few other pics to try and get a better idea of where I am going. its 1' wider on the front and 2 " on the rear.
    my side vents are opened up already width wise and height wise. so you are saying run the flare over to the edge of the vent or try and make a scoop?
    Quote Originally Posted by Lumpyguy View Post
    How big of tires are you going to put on the fronts?
    I am running 235/40-17. I had to do a lot to keep them from rubbing during cornering and rough roads.
    I drive the car on street, autocross and road courses.
    Bowling Green, KY
    I would be interested in a set of fronts if you are planning to pull a mould? My 235 R1 vented and clearance the front fenders for me so I just started playing with flair shapes using construction paper.
    Senior Member EODTech87's Avatar
    Feb 2013
    Copperas Cove, Texas
    Looks like he has 235/40-17 as well.
    Ditto. Lumpyguy why did you stop the front of the front flare where you did? Why not run the shape all the way to the bottom of the bumper?
    -Jason
    San Diego Ca 92106
    I was trying to say to in corporate a scoop into the flare. It would be an aggressive look, more race car than street car though
    Something like this ford gt..
    Jul 2014
    I was trying to go with the liberty walk look allot of them stop short down the front. I have put this project on hold for now its just not working for what I have envisioned. unless I can get the look I want and have everything work It just not worth it to keep going. I might revisit it soon and re do a few things. I might abandon the liberty walk look and just make flares that work better over all
  10. #9
    Puyallup, WA
    Nice work. Im really eager to build a set for mine as well. Work and life has been getting in the way tho (not a priority).
    Im running 255's up front and 295's in the rear and have a temporary rubber flare in the rear to cover the width. The front gets by but i do have rubbing when i hit bridge expansion joints or other bumps with the tire slightly rubbing the inside of the flare. My plan for the rear was to incorporate the widened rear scoops as part of it or somehow incorporate my existing side scoops with the rear fender flares.
    The good thing about delaying my build is that i have more time to figure out what works and what doesn't as well as think about the design a bit more.
    Dont give up yet. Throw some paint on them and see how they blend in without all of the tape and primer colors.
  11. #10
    Edmonton, Alberta
    Those flares look amazing! So much less work than what I did. Don’t give up on it, going to look sweet!
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  12. #11
    Quote Originally Posted by Kurk818 View Post
    What wheel offset did you use?
  13. #12
    Puyallup, WA
    Quote Originally Posted by BrianToronto View Post
    I have MiRo 398's18x10.5 Flat Black 5-114.3 [+20mm] for the rears and MiRo 398 18x8.5 Flat Black 5-114.3 [+35mm] for the fronts. I ended up adding 10mm spacers for the fronts to clear the brembos.
  14. #13
    Member jcpresto's Avatar
    Looks good...here is mine which is flared only in the back about 2.7”. I’m running 315 In back and 245 in front. 52264B9A-19BA-40CD-B4FF-73CA96E7A5B4.jpegB62D2385-6460-4D98-8A16-8F631A0882A3.jpg
  15. Likes AZPete liked this post
  16. #14
    Puyallup, WA
    Quote Originally Posted by jcpresto View Post
    Nice work! Looks like it was always there.
  17. #15
    Jul 2014
    I love those flares. Much better than mine. I like the build in flare. I have decided to do the coupe upgrade so starting with that first
  18. #16
    Senior Member AZPete's Avatar
    jcp, beautiful work!
  19. #17
    WOW, Impressive flares.
  20. #18
    Jul 2017
    The Villages Fl.
    Really looks great!! Is the car painted or wrapped?
  21. #19
    Looks amazing. What offset are you using for those tire sizes? Also, wrapped or painted? It looks fantastic.
